Hi
I have finally decided how to install my projector at home. As I will use Apple TV, I think the best option is to fix a floating shelf to the wall, and screw the projector to the shelf upside down. On the same hand, I will keep the Apple TV on top of the shelf to connect it to the projector
My question now is... should I use any specific shelf? How deep should it be? Which screws should I use?
The whole weight of the projector+mount I will fix to the shelf will be 5-6kg
Thabks
Thabks
