punman
- Feb 16, 2009
- Dwayne
In a 5.1 system, the subwoofer represents one-sixth or 17% of the speakers.
Would you allot one-sixth of your budget for the subwoofer, or more, or less?
For example, if you had a budget of $2000, your budget would be about $340 for the subwoofer. Would you spend around that, or more than that at the expense of cheaper speakers for the other five, or would you say that the subwoofer is not as important as the other five and spend less than the $340?
If you have a 5.1 system, what cost is your subwoofer, as a percent of your total speaker cost?
