saudiboy
- May 19, 2008
- mark
I have a 3 tiered built in; a cabinet on top, the TV cabinet in the middle and drawers below. The built in has mouldings on the side and top. I want to replace the existing tube TV with a mounted flat screen (60 or 65 inches) that will extend to the edge of the mouldings. I want the TV to swing out like a cabinet door so that I have access to the space behind. It seems that there would be a mount that would mount on the side and articulate a bit so the TV would clear the moulding on the mount side, but I can't find anything. Maybe a piano hinge would work if I frame out the opening a bit and attached the TV to a piece of plywood attached to the piano hinge, but I wonder if a piano hinge would be strong enough. Has anyone come up with a solution for this situation.
