RICK BOND
All of a sudden when I go to check my Alerts Ads pop on and Block them. Any one else having this problem ?
Bob,Dave, have you just fixed this problem.? A little earlier I made the screenshots, below, before logging in. After logging in I did not see the blocking ads. I had to go away. And before logging in, I still am not seeing them. or now that I am logged in. Maybe the problem ads pop up at certain times?? Yesterday the ads were persistent even when logged in.
Ads blockings search engine: View attachment 108075
Ads blocking view of a zoomed picture:
Thanks Bob. I am working on the ad issues right now - please stay tuned.Right, the ads on the bottom are not there if logged in. But non-member visitors are not going to be impressed or drawn to ads that block their view. It's dumb. In the past you could click them away. But now. if you click the ads away, a white block appears and then a new ad appears in its' place.
My main complaint, is the ads that cover/block the search drop down box and cover zoomed pictures. That happens logged in or not. If you report the ad blocking the search box, for 'covering content', the ad goes but a white square appears still blocking the search drop-down. As I said before maybe it's a time of day thing, because it does not happen all the time.
Dave, how are you doing with the
wide-screen avatars?
