World Wide Stereo
Yamaha rxv385 not detecting dvd (1 Viewer)
nitroman392
Pete
First time posting, need help. I've bought a Yamaha rxv385, tried to connect samsung dvd with hdmi and just get the connection indicator blinking and nothing happens, I have it in the correct bd/dvd port. My pay tv box is detected and works ok. Do u have to change settings somewhere. The dvd is samsung about 12 years old. In not at home writing this so I don't have the model number atm. Please someone help.
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
Check the Samsung’s menu settings to make sure it is outputting to HDMI. If it is, try a different HDMI input on the Yamaha. You can use any of them. It still doesn’t work, the player has issues.
Wayne A. Pflughaupt
nitroman392
Pete
Wayne A. Pflughaupt
Yep did all that, was playing it hdmi straight to tv ok. When it's connected to the receiver and playing a disc the receiver is not detecting hdmi input signal. If I reach around the back of the dvd and pull out and push back in the hdmi the receiver gets a signal and I have visual and audio on my tv
Edwin-S
It sounds like it is a handshake issue. What sequence do you turn the devices on? DVD player---->Receiver------>TV or Receiver------->DVD player------>TV? The fact that you get a signal to the receiver after unplugging the HDMI cable from the DVD player suggests that the receiver should be turned on first and then the DVD player. Also, maybe check for a firmware update for the receiver? Sometimes, an updated firmware may take care of issues that get identified.
cassidylhorne
