- Feb 8, 1999
- Robert Harris
Fritz Lang's 1945 Scarlet Street is based upon the same lit as Renoir's 1931 La Chienne, and may be considered a remake.
This is one of those films that's been locked in PD purgatory since (presumably) 1973, and therefore hasn't been seen in any prime form, unless you consider a horrific colorized version of interest.
The film holds up today, with Edward G. Robinson cast as the timid bookkeeper, who runs into femme fatale Joan Bennett and her "friend" Dan Duryea.
The new 4k, which fortuitously is not billed as a Restoration, is taken from a comp fine grain held by UCLA. The element is fine outside of minus density during the opening and either an element re-cut or a timing defect also during the main titles.
Other than that, the new 4k is fine with a single exception. The fine grain doesn't hold enough resolution to warrant 4k. I checked the accompanying Blu-ray, and while the grain structure is a bit more highly resolved in the 4k, there is no deal added, especially when one begins the discussion of those dastardly seating distances.
Density is a bit of a problem, as the differentiation between black and those levels just below lack any bit of air.
And yet, this is the nicest representation of the film that I've seen in decades, so kudos to Kino for making the effort.
Is 4k justified? I don't believe so, but at under $19 at street, you're actually not being charged for it. Just seems like a waste of the 4k production line, which could just as easily be used for the likes of Ben-Hur.
Image – 6 (Dolby Vision)
Audio – 7 (DTS-HD MA 2.0 Monaural)
Pass / Fail – Pass
Makes use of and works well in 4k - 2
Worth your attention - 8
Slipcover rating - 1
Highly Recommended
RAH
https://www.amazon.com/Scarlet-Stre...06954097&sprefix=scarlet+street,aps,83&sr=8-1
Pass / Fail – Pass
Highly Recommended
RAH
