- Feb 8, 1999
- Robert Harris
It's nice to see Kino releasing more black & white classics in 4k UHD, but sometimes I wonder if it's worth the trouble and expense.
Billy Wilder's Stalag 17 is a perfect example.
Don't get me know. There is absolutely nothing wrong with releasing 70 year-old black & white productions in 4k. They can look great, and this one does also.
One of my pet peeves in packaging is that I prefer to find the more highly resolved disc mounted to the right of a case, when in combination with another. It seems that probably 90% of the time, the higher resolution disc is on the right, but on occasion...
Such was the case, with Stalag. I played the Blu-ray, being uprezzed to 4k in projection, and thought it looked terrific, especially as I'd hear aeons ago, that the OCN was AWOL. This is unconfirmed.
As I removed the disc from the player, I happened to check, and found that I'd been viewing the Blu-ray. So I popped the 4k into the player.
What I found was similar to so many other instances in earlier productions, where the OCN probably tapped out at 2k or less, so where is there to go, beyond adding a layer of Dolby Vision, which my projector cannot decode and projects as HDR.
The difference between the two at the screen, was minimal. The 2k had a tiny bit of softness around the grain structure, but from a nominal seating disturbance, there really is no difference.
So the question is asked once again. What is the purpose of releasing a 2k project in 4k?
It eeks out every last bit of detail that "might" be on the element, and that's fine. Especially for a film the quality of Stalag 17, which beautifully stands the test of time.
Image – 5 (Dolby Vision)
Audio – 5 (DTS-HD MA 2.0)
Pass / Fail – Pass
Makes use of and works well in 4k - 3.5
Upgrade from old Blu-ray - Yes
Worth your attention - 10
Slipcover rating - 2
Highly Recommended
RAH
Thank you for supporting HTF when you preorder using the link below. If you are using an adblocker you will not see link.
Pass / Fail – Pass
Highly Recommended
RAH
