Elite also makes a floor standing, retractable screen if DIY isn’t your thing and you just want something that can be easily set up and put away after each use.
Right. Not sure if they have other (better?) models offhand, but the portable screen I use is indeed an Elite one (a Yardmaster 2) that's reasonably quick/easy to setup and break down... though still can take upto maybe 30min or so to set up, especially if you're doing it alone and/or new (or just very rusty) at it -- maybe w/ plenty of practice, can be set up in as little as 15min perhaps.
_Man_
Yes but I bet it will break sooner or later wish they had a rating on how many times you could pull it up and down before breaking in generalYou’re talking about outdoor portable screens. I’m talking about indoor portable screens like these:
ezCinema 2 Series
Buy easy to use free-standing project screen from Elite Screens Inc. It comes with a scissor-backed free-standing mechanism. Shop now!elitescreens.com
I had very good results with one of these several years ago when it was not possible for me to hang a screen directly on a wall. This does not take 30 minutes to set up, more like 30 seconds. You put the case on the floor where you want it to go, and pull it up. That’s it. When not in use, the case can be stood vertically and stored in a closet or corner. It’s meant for people who want to use a screen indoors but can’t anchor anything to a wall.
Cool. It has pets two cats but they mostly are ok with new stuff.If you just need a screen that is going to stay in the same place all the time, it seems to be pretty easy to figure out a sturdy floor standing posts to attach the screen to -- either 2 vertical posts (heavy wood or steel) or 2 vertical posts and a horizontal top post. If it's truly fixed/semi permanent then something custom made would make sense. It seems it would be simple enough to add masking or decorative material to fit into the room decor. I could easily imagine some sort of retracible screen would work. Nothing attache to the ceiling or walls. Is it a dedicated Media Room or a multi-use room esp with kids/pets/windows/doors etc
If it needs to be movable then it gets more complicated though
A lot depends on how wide the room is and what you want it to look like when not in use.
ezCinema 2 Series
They don’t sadlyHmmm... too bad they don't offer one significantly bigger than my 120" or I might consider it for my own current setup (though I'm not completely sure offhand my setup's throw range can allow quite that much bigger) -- actually, they don't seem to go quite as big as 120" (for 16x9) either.
_Man_
_Man_
Check out series 1 - the series 2 models I linked to have a scissor backing and the size of that mechanism limits the possible screen size. The series 1 models use straight rods instead for the backing and come in larger sizes. They take slightly longer to set up (2 minutes instead of 30 seconds) but if size is important you can go bigger in that line.
If money is no object there’s yet another line that has an electric mechanism to stand up and retract via a motor rather than pulling up by hand.
People keep telling me a fixed frame screen is the way to go because it is higher quality and cheaper.
