What kind of stand do you use?Well, there's no doubt of that... but then you threw in that sticky/tricky requirement that makes installation an essential non-starter... unless you go w/ some kinda (largely) fixed stand instead, which is basically what I did -- although my screen/stand is portable (enough), I just leave it fixed in my current, makeshift setup... and it's quite inexpensive, especially compared to all the discussed (non-DIY) options.
_Man_
