You don't need a "Dolby Atmos speaker" to play Dolby Atmos, any more than you need an "HD antenna" or "4K antenna" to receive those broadcasts. You will need to buy separate height speakers to add to your existing surround sound setup to get the proper effect, but they don't need to be labeled "for Dolby Atmos".If i have an A/V receiver which supports dolby atmos... Can i play dolby atmos audio at any speaker ?? Or do i need to get specific speaker model which support dolby atmos??
Yes. You should do research to find out which models work best for the height channels, but don't worry about them being labeled "for Dolby Atmos".So i can buy any bookself speakers to get a dolby atmos surround sound ... Right?
No, not really. To take advantage of actual Atmos, you need at least one pair of on-ceiling or in-ceiling speakers. Not just a pair of "height" speakers above the fronts. That or a reflecting pair of "Atmos Enabled" speakers, which aren't nearly as effective, and might not work at all, depending on your room and ceiling.So i can buy any bookself speakers to get a dolby atmos surround sound ... Right?
