Idol Thoughts
- Jan 20, 2019
- Knick
Recently purchased Samsung BD-J5700/ BD-JM57 Wi-Fi Blu-ray Disc Player with Tyler 6ft HDMI Cable (Certified Refurbished), and, because I'm using a fairly old TV, I also got GANA HDMI to RCA,HDMI to AV, 1080P HDMI to AV 3RCA CVBs Composite Video Audio Converter Adapter Supporting PAL/NTSC with USB Charge Cable to use it.
It was fine at first, but the audio soon started crackling whenever sound would come out. Naturally, I turned the Google and saw others with the same issue, including on this very forum. None of the solutions worked (like adjusting audio settings) except for giving me the idea to straighten out the audio jacks. Keeping them as straight as possible seem to do the trick.
It was fine for weeks, but the problem came back. The next day, it was fine again. A few days later, it's back again, and I can't fix it. It crackles and sounds like it's blaring from another room. I have it hooked up to a stereo, but I've established it's not that. I tried using different A/V jacks, and it's not that. Nothing I do does anything. Please help!
EDITED TO ADD: One more quick check before bed, hoping it's working. It's not, but the sound seems to be coming out one speaker okay, while still crackling in another. Easier to hear, though--less of that "blaring from another room" effect.
