Nelson Au
- Mar 16, 1999
I plan to pre-order an iPhone 12 Pro. Likely the white version with regular stainless steel sides. And I’ll max out the memory. I’ll likely keep the iPhone 12 Pro for three years, so why not max it.
I was torn about which size iPhone 12 Pro or Pro Max to order, so I decided to draw up the iPhones. I’d already built the iPhone 6 in 3D CAD, so I modified the CAD to the external dimensions of the iPhone 12 Pro and Pro Max. I don’t have access to the Apple Developer site with the newest detailed drawings of the iPhone 12, so I used Apple’s dimensions on the iPhone 12 Pro webpage.
I think this might be helpful as I think others might be in the same boat. In the image below, I’ve placed my iPhone X next the drawing of the iPhone 12 Pro. To the right of the Pro is the drawing of the iPhone 12 Pro Max. And to the right of the Pro Max is a 3D print I made of the iPhone 6+ that I built in CAD back then. From this experiment, I can see the iPhone 12 Pro is physically a little taller then my iPhone X and the screen area on the iPhone 12 Pro is taller By about 2mm. the Pro is about the same width. The iPhone 12 Pro Max is a big upgrade in size from the iPhone X. Compared the iPhone 6+, the Pro Max is about 2mm taller. So very close in size to the iPhone 6+. From what I can tell, the magnitude of size difference seems to remain as before. The Max is about the same as the old iPhone 6+. But the difference from the iPhone X and iPhone 12 Pro is taller by about 2mm. Or wider depending on if you hold it in landscape mode.
I may glue this print-out onto a piece of foam core and cut these out to get a better sense of size later today.
(I didn’t see a new thread yet, so I thought I’d start one. If not appropriate, please moderate as you see fit.)
