World Wide Stereo
Speaker Placement (1 Viewer)
paulLA
I am moving into a new home soon and would like suggestions on the rear surround speaker placement. I have attached a couple of scenarios I was thinking of.
At the top of the drawings you see a 4 foot wall. Should I mount one speaker there just under the counter top or just put them on the back wall or what?
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
If the seating is going to be against the wall, use the pink locations. If the seating is going to be mid-floor about 10-12 ft. from the screen (preferred), use the green locations.
Wayne A. Pflughaupt
paulLA
Wayne A. Pflughaupt
Thanks for such a quick reply. Yeah, seating will be against the long wall.
Josh.1983
