Receiver: HT-R540
2 Speakers: JBL SP6CII
Receiver is rated as
120w + 120w (8ohm Front)
170w + 170w (4 ohm, Front)
Speakers are 8 ohm
Speaker spec says: maximum recommended amp power is 80w
Im trying to use this old home theater receiver to power these brand new JBL speakers I just got. I will be using them for music only.
1. Do I put both of these speakers on one wire to get the wattage down to 60 each?
2. Do even need to worry about wattage being way over as long as the ohms are correct?
3. Does the "120w + 120w" mean left and right front?
Thanks!
Speakers are 8 ohm
Thanks!
