subwoofer hum (1 Viewer)
Dwayne89
Dwayne Philpot
hi i have a subwoofer in a home theater.it hums realy load. and gits louder when you turn the gain or crossover knobs. Anybody have any idea. any help will be grate thank you. ahead of time.
Stephen PI
I had a similar issue recently and I lifted the ground pin from the ac plug, with a two pin adapter, and it solved the problem.
MasonStorm@HTF
