World Wide Stereo
Yamaha RX-V683’s speaker Test (1 Viewer)
Dave Scarpa
David Scarpa
Setting up my receiver and speakers in my new home media area. Utilizing the receivers test probe mic and auto setup. It’s finding one of my back surrounds with a wiring polarity error when the is absolutely not one. Double checked on both sides it’s is wired correctly. I am using banana plugs on the receiver side but I checked them too. Any ideas ? Is it just a wonky diagnostic?
JohnRice
Bounded In a Nutshell
A Mile High
Is there any chance the banana plugs themselves might be switched on one end? Or, are you also double checking the wire itself for correct connection?
Dave Scarpa
David Scarpa
I switched the wire on the speaker in question and the polarity error went away so the only thing I can think is the wiring in the new pioneer atmos speaker is wrong inside I’m going to have to crack it open and check it out
John_Bilbrey
My Denon did the exact same thing recently, except it was one of the side speakers. I double-checked everything. I ended up telling it to ignore the error and continue on.
Josh.1983
