Nelson Au
- Mar 16, 1999
Thanks Doug!
i pre-ordered back in August from Best Buy. Sometimes I get my shipments early, sometimes later. Luck of the draw.Thanks Jake, Doug and Rodney for chiming in! And thanks Rodney for confirming. How did you get the Steelbook early? And yes, Amazon and Best Buy shows the Steelbook, but doesn’t let you order it. So I’m curious how Rodney was able to get the Steelbook?
The decision to make the standard 4K release a single disc is bizarre to me.
If you ordered the steelbook and they had enough stock to accept the order, then you should get the steelbook. The other editions would be cheaper, so if they send you something that isn't the steelbook, you've been overcharged.I still feel like I might not actually be getting the Steelbook, so I’ll see when it arrives.
Right. I understand your point. I don't expect to need the 4K disc -- I'm okay with the Blu-ray -- so it doesn't really impact me personally. I just think it's weird that they are pretty much the only major studio that does it this way.For better or worse, this has been Paramount’s standard release strategy for new releases films and newly remastered catalog titles for at least a year - there have been some exceptions but I think their bean counters have concluded that the cost of adding a disc to the package is not outweighed by the number of units sold.
Hi Jake, yeah, I figure that you are right. Just hope the computer system shows there’s enough stock on hand and the reality of the quantities in stock match.If you ordered the steelbook and they had enough stock to accept the order, then you should get the steelbook. The other editions would be cheaper, so if they send you something that isn't the steelbook, you've been overcharged.
I think if they didn't have stock on hand, you wouldn't be able to place the order. But I understand your skepticism. I have had varying degrees of success getting steelbooks in the past, but never had a problem once I placed the order.Just hope the computer system shows there’s enough stock on hand and the reality of the quantities in stock match.
the one and only Christopher Nolan DVD i have in my library, DUNKIRK, is shifting ratio....But I was wondering if anyone knows how the DVD release will be handled. We know that the Blu-ray, UHD and digital versions present the film in the shifting IMAX aspect ratio. But I haven't heard about the regular DVD. Christopher Nolan's Blu-rays use the shifting ratios, but his DVDs present a fixed scope aspect ratio version...
That's interesting. If we assume that Paramount would treat its Tom Cruise franchises the same, I guess this means the DVD of Maverick is also shifting ratio and the scope version is not being released.Tom Cruise last Mission Impossible DVD, FALLOUT is also in shifting ratio.
Huh. Do the Canadian digital versions often differ from their American counterparts?The Canadian digital redemption for this...Didn't include any of the extras.
There are folks who like "stick to the theme" aspect ratio presentation.That's interesting. If we assume that Paramount would treat its Tom Cruise franchises the same, I guess this means the DVD of Maverick is also shifting ratio and the scope version is not being released.
Not sure, but redeeming to iTunes gives the following when you go to the iTunes Extras tab via the app on the computer. Via the Apple TV device... the movie will only play. Trying to click on either of those bonus features simply shows a pointer with the circle with a line through it.Huh. Do the Canadian digital versions often differ from their American counterparts?
