World Wide Stereo
Audio Input Question (1 Viewer)
Foxman
North Carolina
Russ
So, I posted in another thread that I am finally upgrading my 20 year old Rotel processor (works great but no HDMI) for a used 2016 Anthem that offers a wide variety of connection options. For video, the clear winner seems to be HDMI, but is that true for audio?
I have the option for HDMI (7 inputs), component (5 inputs), optical (3 inputs), & Coaxial (2 inputs). From what I understand, I can assign any audio input with any video input. Since I haven't had to deal with this many variations, what is the preferred order of operation? Any in-put (pun intended) would be appreciated.
The ones I am unsure about that I will be connecting are a Tivo device with a variety of options & an external DAC which I run my phone through. I'm pretty sure everything else is HDMI only unless my Blue Ray offers a component or Coaxial option.
JohnRice
Bounded In a Nutshell
A Mile High
For your video sources, you want to use hdmi for both audio and video. I'm not sure I totally understand your question beyond that. Audio only sources probably have multiple options and deciding on which to use will require more detail of what options you have.
Foxman
North Carolina
Russ
@JohnRice that helps actually. Since the Anthem gives the flexibility to assign a different audio input from the Video, I wasn't sure if there was a better option than HDMI. Thanks, as always you are quick with a solution.
JohnRice
A Mile High
No problem. Glad to help. The bottom line is that hdmi is the only method that can transmit the latest audio formats like HD and Immersive (Atmos/DTS:X) so it's really the only one to use for those formats.
Gemini007
