RoyKeane
- Apr 19, 2011
- j getman
Hi everyone - I have an audio setup question (sorry in advance for the length of the post)
I have the following components:
-Panasonic TC-L37U3 HDTV
-Panasonic DMP-BD75 Blu-Ray
-Yamaha RX-V461 receiver (the oldest component...surround sound, DTS decoder, etc, but no HDMI inputs)
-Comcast HD Receiver/DVR
The best video setup seems simple - connect both the cable box and the blu-ray player directly to the TV via HDMI cables
My question is about the audio setup.
I have heard that you should NOT filter the audio from the TV to the receiver and that, instead, you should connect audio directly from the components (in this case, the Cable box and the blu-ray) directly to the receiver.
My receiver does NOT have HDMI inputs.
The receiver DOES have 2 optical inputs, though, and the cable box/dvr has an optical audio out, so I was going to make that connection directly.
The problem is with the Blu-ray. it only has "AV cable" audio output (other than the HDMI, which I have already connected to the TV). This leaves me with two choices:
1) connect blu-ray audio out to receiver via the l/r av cable
2) connect the tv to the receiver via the tv's optical audio output and access the blu-ray's audio that way
Which connection gives me any chance at receiving optimal audio (DTS, etc)?
Thanks, in advance, for your help!
